smoking
    smoking
    on the way home from the track my car shut off while driving on the highway. Pulled over and tried starting and it fired up then started smoking like crazy. It has 35 psi compression number 4 cylinder other cylinders are fine. I think my rings collapsed.
    what kind of engine?
    I <3 G60.
      h22a
        Originally posted by afief View Post
        h22a
        Rings dont usually go all to hell at once.Re do the compression test put a table spoon or oil cap full of trany fluid or oil into the bad cyl if it raises the psi more than 20psi you got bad rings but if it doesnt its probly your valves on that cyl.Hope this helps GL!
        02 Crv
          probably scuffed a piston or scored a cylinder.
          I <3 G60.
            good advice thats what i had in mind
            use oil though lol
            -Tyler
              use oil though lol
              All does the same either it seals the rings or it doesn't.
              02 Crv
                how could it be the valves? I have`nt tested yet due to lack of time.
                  Burnt valves can and will cause smoke and low compression.They go bad like everything else over time.But the test will tell you alot.When you do the re test and oil trick on that cyl let us know.First do another dry test tell us psi then do a wet and tell us.
                  02 Crv
                    I did a compression test again dry and with oil. dry it was 40 with oil it jumped up to 120 so its my rings.
