My radiator fan stopped working...its not the fan as i tested it direct and it works. What else could it be or does anyone have a fan wiring diagram?
Radiator fan problems!!!
you should really use the search engine
and
did you check the relay if its not that it could be 1 of 3 temperature sensors or the fan timer relay-----------------------------------------------
''It is what it is, Do what you want''
http://www.cb7tuner.com/vbb/showthread.php?t=167905
