Well just got a 92 cb7 swaped with a f22b1.Its running a p0A And im needing the correct pin outs for this ecu to wire up vtec any and all help would be awsome!
VTAKKKKK issues need a lil help!
02 Crv
Tags: None
Anyone? i pin'ed A4 and D6 that everyone has been telling me is the same for vtec on all obd1 ecus, but im not seeing it cause it basicly thru the ecu into limp mode choppy rev and limiter at 3500 so theres bound to be a trick to it or def pin location for this ecu?
02 Crv
Originally posted by deevergote View PostBumping your thread once an hour is a good way to get it deleted.
I would PM DarkCloud. He wrote the DIY on how to install an F22B1, and would certainly know what to do. The pinout info doesn't seem to be in that thread, so it might be a good thing for him to add after he helps you.
02 Crv
If this is not a vtec harness should there be any wires in the a4 and d6 locations?Everyone and everywhere im seeing all the obd1 vtec ecus have the same pin location for the Soleniod and the switch but if the prev owner didnt swap the harness should there be wires there?
02 Crv
Need to firgure this out ASAP fellas any and all help would be great!
02 Crv
what im saying is theres wires for those pins on the ecu under dash harness i tried the pin out i was told to do and went straight into limp mode.
02 Crv
