F22b dilema!!!!
    F22b dilema!!!!
    i have a 91 accord with a f22a4. turns out my pistons are no good. so i wanted to know if its a good idea to get a f22b block. would everything from my f22a4 be compatible with the f22b?
    No, everything would not be compatible.
      Just buy another F22a4 block if you want to use all the rest of your F22a4 parts.
      Get it from the JY or get it new. Since its the same engine your sure everything is 100% compatible.
      Not completely sure but i think any F22ax block will do.
      Rides:
      Accord
      92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
      96-AUDM-2.2 VTiS- Heather Mist
      CR-X
      88-JDM-Si- Black
      CR-X Del Sol
      92-JDM-SiR "Transtop" Motegi Edition - Silver
      95-JDM-SiR "Transtop" Daytona Edition - Silver
      92-JDM-SiR "Transtop" - Black
      Prelude
      91-JDM-Si-4ws "Si States" - Phoenix Red
      91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
      91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
      91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
        Buying a good used F22aX engine and bolting it, is in my opinion easier and cheaper than changing blocks, head gaskets etc etc.
        However it may not last as long as one with a new cylinder rings and walls etc. (well the block component any way)
        Depends i guess on how long you intend to keep the car (and what condition it currently is).
        Rides:
        Accord
        CR-X
        88-JDM-Si- Black
        CR-X Del Sol
        Prelude
          You'd be taking the motor apart to put the head on a new block... you could simply take the motor apart and replace the pistons in that case!
            yea thats true
              Mismatching blocks is never a good idea. The F22B DOHC block is nearly identical to the F22A block, and the F22Bx (5th gen) are similar. You COULD do it, but the more you mix things up, the greater the chances are that you'll do something wrong, and have an unreliable engine. Mixing up blocks and heads are best left to pure project cars. Cars that you can afford to have blow up if you get something wrong.
                i found a 97 accord engine for 350 its manual and has 154k on it. would it fit to the transmission?
                  The transmission, yes. Mounting it will take some modification. Converting it from OBD2 to OBD1 will take some modification. It's a fair amount of work for an engine that won't be any better than what you have. If you're going to go through that much of a hassle, shell out a couple extra bucks for an H22 and at least upgrade! Or an F22B DOHC for about $750. 60hp and direct drop-in. Not a bad deal.
                  97 Accord motor is also a terrible platform for performance upgrades compared to the F22A.
                  I sold my F22A1 with the transmission with 166k on it back in 2003 for $50. The deals are out there.
                    still havent found a good deal on a f22. anybody know of a good site?
                      craigslist.org
                      COUPE K24
                        thats were i been looking
