5
Nobody can help me ? I'm stranded !!!!
Originally posted by 91'BLKex View Post5 threads down 'Emergency', nobody even looked at my thread ? I'm stranded, I need to start my car, and your looking at comparing motors ?Originally posted by 91'BLKexI pulled various fuses and plug wires in an feble effort to foil stupid thieves. Instead I just confused myself trying to re-start the car. It cranks, I smell gas, I'm getting spark. I checked the Honda manual the firing order is 1,3,4,2 clockwise on the dist. correct ? And plug wire order is 1,2,3,4 starting at front of motor right to left standing in front of car, correct ? I repaced all fuses too. ??? help
Here's the best advice I can give you. CHECK IT ALL OVER COMPLETELY.
If it was fine before, and everything is the same, it should start. If it doesn't, you've missed something.
#1 is closest to the cam gear on the head.
And buy an alarm. Even a cheap POS $30 alarm will deter thieves as much as anything. If they want it bad enough, they'll take it.
Good luck.
YOU POSTED THAT THREAD A 4 O'CLOCK IN THE FUCKING MORNING! Of course nobody even looked at it!
You also gave very little helpful information in your other thread. You said you pulled fuses. You said you smell fuel. You asked about the wire order, but didn't mention removing the wires... so why even ask?
Yes, we're talking about comparing motors... because there are 26,559 members on this site other than you. Yes, we don't instantly focus on your problems when you do something stupid. Most of us are sleeping at that time, honestly.
You smell fuel, so that's ruled out. Check for spark. If you don't have spark, check all electrical connections... battery cables, grounds... Verify that you put the correct fuses back, and that they aren't blown. Then look into replacing your ignition coil and ignitor.
The next time I see a "I posted a few minutes ago and nobody helped me you guys suck!" thread from you, I'll simply ban you. That is quite disrespectful to the people that you are asking to help you.
Not starting
Thanks for all the advice. I plan on getting various 'kill' switches too.... I just got impatient. I apoogize. I really needed to get this car going to be someplace at 8:00 a.m.. I'm just mad at myself for getting into this mess. The firing order is correct, I'll recheck the fuses. It was running fine before I started pulling stuff and disconnecting things. I outsmarted myself !!
Originally posted by 91'BLKex View PostThanks for all the advice. I plan on getting various 'kill' switches too.... I just got impatient. I apoogize. I really needed to get this car going to be someplace at 8:00 a.m.. I'm just mad at myself for getting into this mess. The firing order is correct, I'll recheck the fuses. It was running fine before I started pulling stuff and disconnecting things. I outsmarted myself !!Last edited by rob_is_legend; 09-21-2010, 11:47 AM.
OP: cylinder number one is the opposite what you wrote (or I misunderstood what you wrote): it is furthest to the right while you are standing in front of the car facing the engine.
cylinder number 2 is right next to it.
etc on to cyl 4
__________
distributor spark order is as stated by you and also restated above. spark plug one dist spark is the spark tower that is in the front of the distributor and somewhat close to 5 o'clock if you are looking at the dist from the passenger side fender. the other spark plug wires follow clockwise.
Make sure your primary ignition voltage connector is hooked up and your secondary as well.
A quick way to go with the kill switch idea might be to get a faulty main fuse and install that when you are parked in a bad area. If you don't have a faulty main fuse you can make one by blowing it yourself. just connect it terminal to terminal to the battery with a decent gauge wire and it will burn out in about .2 milliseconds.
Course if you are in a bad area you might have occasion to get in your car and drive away quickly and so the dedicated kill switch is a better idea--although a real car thief will be able to find it unless you put it someplace really weird like in the trunk or something.Last edited by batever; 09-21-2010, 05:32 PM.
Originally posted by 91'BLKex View PostI'm not getting any spark. Distributer ? Igniter ?
Since you still havn't stated what you "Pulled and disconnected" It could be anything.
Is the Dizzy plugged in?
My 5.7 LS1 Holden Ute
