Any recomendations on the best manual?
    Have owned alot of cars.
    I know, One manual will suck, and the next will be really clear and complete.
    So, Whats the best manual for a 92 ex. I'm sure 90-93 will be every manual
    But whats the best you have had or seen ???
    recommendations
    My YouTube channel
    https://www.youtube.com/channel/UCWG...y6tJ7wJMI4J8vA
    Instagram
    https://www.instagram.com/dreamability71/
    Members Ride.
    http://www.cb7tuner.com/vbb/showthread.php?t=210942
    For just about any Honda, use the factory service manual. They're normally $25-$100.
      www.helminc.com
      The only other options are Chilton's (which covers all Accords and Preludes from 1984-1994... which is a HUGE range of very different cars, all jumbled together!) and Haynes (much better, but not written very well...)
      Those two cheap ones are good additional references, but if you really want to work on your car yourself, the Helm manual (which is the factory manual) is one of the most valuable tools you'll ever buy.
        No manual is perfect (which really means you can get stuck, or undone in a middle of a job with just one).
        I suggest a multi pronged approach.
        I use Chiltons, but even that has minor errors or missing information (I'm sure another manual will have its errors also).
        However if you have Haynes, it may have its short comings where the Chiltons does not.
        Combined manuals will cover more bases (so if your lost with one manual's explanation or dont think its right you have another to back it up or explain it clearer).
        Just additional info:
        However no manual will give you a practical approach and actual experience (common problems and fixes) from a non standard point of view. These manuals approach the issue from a perspective all works as intended (no alternative measures and non-standard approaches which a 20yr old car may have).
        Supplement the ideal "text book approach" (which these manual really are) with the practical approach (actual problems, mysterious findings and subsequent fixes and answers) using the Net and CB7Tuner. The practical approach i find really compliments the text book approach.
        Rides:
        Accord
        92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
        96-AUDM-2.2 VTiS- Heather Mist
        CR-X
        88-JDM-Si- Black
        CR-X Del Sol
        92-JDM-SiR "Transtop" Motegi Edition - Silver
        95-JDM-SiR "Transtop" Daytona Edition - Silver
        92-JDM-SiR "Transtop" - Black
        Prelude
        91-JDM-Si-4ws "Si States" - Phoenix Red
        91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
        91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
        91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
          agreed.
          the ones they have at the dealership beat the crap out of chilton's, helm's, and haynes. but if you're somewhat mechanically inclined, you could do fine with any. later.
          Avoiding dirt at all costs
            x2, Haynes and Chilton can lead you down the wrong path in a hurry if you're not paying attention.
            Google around for service manuals, you'll be able to find a lot.
            http://manualspace.com/honda-accord-...ice-manual.htm
            http://pdftown.com/search/node/honda...service+manual
              Go to DIY section, look at the sticky there is online link to Chilton Manual for any car
                Thanks Everyone
                Yeah through experience I knew Haynes and Chilton suck.
                I'd be halfway through the job thinking, "Where is the missing page".
                Not fun.
                Did not know about Helm's. But it seems a step above.
                Called the dealership with no luck.
                They told me to go to Helm's
                TypeG, can you get a Honda shop manual? And where?
                I'm just getting it now to do the port seals and cam seal,
                so I'll know the torque and sequence. However next year she goes in the yard for a full rebuild, so I need the most complete reference.
                And of course the support of cb7tuner
                My YouTube channel
                Instagram
                Members Ride.
                  TypeG can get them the same place you can get them... www.helminc.com, like I said above.
                    i believe that he was under the influence of TypeG saying that
                    Originally posted by TypeG View Post
                    ...the ones they have at the dealership beat the crap out of chilton's, helm's, and haynes...
                    and was thinking that helm's has a manual that is different from the honda shop manual
                    ''COUPE''
                    ''WAGON''
                      Ah, ok.
                      The Helm manual IS the Honda manual.
                      From www.helminc.com
                      Why Buy Original OEM? Why Helm Publications?
                      * Helm only sells manuals written by the manufacturer (Original OEM), designed specifically for your vehicle or equipment.
                      * Original OEM Manuals are more accurate and complete than any other service information available. OEM Manuals contain thousands of pages of diagnostic and repair information!
                      * These are the same manuals your dealer service center uses so you know you're getting the technical information needed to service and maintain your vehicle or equipment.
                      * Many OEM Manuals include diagramed repair and replacement procedures, electrical diagrams and training information.
                        Live and Learn
                        Thanks Again.
                        I'll be ordering mine now from Helm Inc.
                        And Yes I thought it was different.
                        But, it should have been an obvious clue when that's where the dealer told me to go.
                        My YouTube channel
                        Instagram
                        Members Ride.
                          Helm's manual you can buy is the same one the dealer has. The manual does assume you have a working knowledge of cars.
                            Very true, but no more than any of the cheaper, crappier manuals.
                            The Helm manual lays it out very clearly, with detailed diagrams. If you can't figure it out by the diagram, the instructions, and actually looking at your own car... then perhaps it's time to pay a mechanic and choose another hobby!
                              I agree
                              And thank you for that advice.
                              I need the manual for torque specifications
                              So when I use my proper calibrated torque wrench I can
                              not screw up and twist a bolt off and make sure I follow the right bolt
                              sequences.
                              I am a beginner here and with the cb7, not with auto mechanics.
                              My 92 ex is my daily driver for the rest of this year, (270,000 miles)
                              And I have to keep her in shape until next year when she goes in the yard
                              I fell in love with cb7's the last year after owning two.
                              I bought the 92 ex with the strict intension of a full overhaul.
                              Call me crazy, but I love that car.
                              Anyway, I wanted to make sure I was getting the most complete reference for our cars from the get go,
                              because of the full rebuid next year.
                              So thank you again.
                              No ... I'm sure I have the right hobby... lol.
                              Cars rebuilt to date:
                              1960 Ford Falcon (stock 144cu)
                              1972 VW Bus (1600cc to 1971cc 72mm crank, duel double barrel webers with 6" velocity stacks and K&N filters, KYB suspension, and custom home made brake vacume chambers made out of PVC to make it stop on a dime.)
                              1979 Accord Sedan CVCC ( stock 1751cc)
                              My YouTube channel
                              Instagram
                              Members Ride.
