Stock Tranny problems on Jdm F22b Dohc!!
    I have a stock accord 5sp tranny on a F22b dohc. The problem i'm having is it grinds into 3rd gear only at high rpm. What could cause this?? Should i swap the tranny out and what tranny would work best with that F22b?
    The grind has absolutely nothing to do with the engine. Your synchronizers are wearing out. It needs to be rebuilt. Try changing the fluid. Use GM Synchromesh. It won't fix the problem, but it might keep it from grinding as much... giving you a little more time.
    The best transmission for that engine would be the transmission that Honda mated with it in the Prelude Si.
      Thanks i will change the fluid with Gm synchromesh in the mean time until i swap the tranny out.
