my car wouldnt start today, its a 91 accord ex. here's what its doing, when i try to turn on my car and turn on the ignition switch i hear a click and then everything dies, like it just loses power, but then when i go and move the wire around the battery it gets power again and when i try to go start it, it does the same thing so idk, and then when i tried jumping the car to see if it'll start, sometimes it doesnt start even when i jump it, but sometimes it does too. so idk any ideas on whats wrong? i went and got the battery check and they said its fine, so im thinking maybe the starter or alternator?
cb7 help?
Originally posted by cb7_530 View Postok thanks i'll try that, but if that doesnt work, what could the other problems be?Sig removed due to excessive size.
Originally posted by osl View PostStarter if it just clicks once. Try holding your key in different positions (near the starting position) and see if it starts. If it does, ignition switch.
oh and i forgot to mention we tried push starting it too and it didnt turn on either, dont know if that helps.
try this turn the ignition switch to the on position and see if the lights on the dash light up , if they are not on slowly turn the key to start position and see if the lights liht up, if they light up , now let the key come back to the run position, if the lights turn off , you have a bad ign switch .......
