Complete A/C system install tips
    Hello, as the title states I will be fully redoing my a/c system, this includes evaporator core, condenser, compressor, accumulator/drier, expansion valve, both suction and desuction hoses, all o rings, inline refrigerant filter.
    (let me know if you feel as if I have forgotten anything excluding the blower)
    Now I kindly ask you all for any tips you may have for me, regardless of how big or small. And i stress the word 'any'
    Another thing that would help is a US version 1992 Honda Accord EX sedan service manual so that way I am knowledgeable of all torque specs.
    thanks
    thanks
    i believe there's a pretty good diy on this
      Did your car come with A/C already installed? But was pulled out for whatever reason?
      If the car already had A/c that means that the wiring for the relays are already there.
      The Fan and wiring should already be there.
      With that being said, i suggest you start from the Outside -> In.
      Installing the evaporator is the biggest pain in the butt.
      Anyways, good luck, take lots of pics.
        @rum_n_coke would you happen to have a link or know as to where I can find the diy at?
        @Jack Frosstwhite The car did have A/C, I'm just replacing all the components of it
          This is an excellent DIY.
          http://www.cb7tuner.com/vbb/showthread.php?t=165508
          I'm going to dive into it next spring, before it gets hot.
          90 Accord Ex, F22A4. Slight fire damage.
            Oh wow that DIY is literally golden
              O yea, i forgot to ask this, after the entire ac system installation. How many oz. of R-134a do you guys think I would need?
                Bump
                  bump
                  What Do You Tell a Chick With 2 Black Eye's?
                  Nothing You Already Told Her Twice
                    bump
                      hey there well the amount of R-134a your system nees depends on what kind of compressor you have and how much you loose to purging the lines when recharging. When i made the DIY i used 4-12oz cans which is 3lbs of R-134a. But like i mentioned before you loose some to purging the air out of the lines, so roughly about 2 1/2 to 2 3/4 lbs should leave you feeling nice and cool in the cabin also i added a little more PAG oil to the system which left less room for R-134a when retrofitting because its better to have a well lubed compressor and loose a few degrees in cabin temps than to have your compressor dry run once and blow. Hope this helps , also if you have any questions feel free to PM me
                      Peace,
                      Gummiegorilla.
