help
    help
    all of a sudden the car shuts off when i reverse and it wont start, the engine was running strong. i checked the fuses and spark plugs. what else could it be?
    Is your check engine light on?
    Bought From : SE_DynamiK, oneoffaccord, and TopCop182
    Click It!>>>><<<<Click It!
      yeah, but it has a h22 swap. its always been on.
        Next thing would be to check fuel pressure. Also check your main relay under the steering column, they sometimes give up at random.
          okay thanks, ill reply if that dosent work. been alot of help.
            If the check engine light is on, something is wrong. It doesn't matter if you have an h22 swap. It should not be on. Pull the code and see what is wrong.
