need some help or advice as to how i should go about breaking/loosening this axle nut..the axle i need to swap into my car is installed in the knuckle from the donor car...naturally the entire rotor wants 2 spin as i try to loosen the axle nut..any suggestions?
breaking axle nut, knuckle already off the car
youre only chance with this is if you can take a large pipe or crowbar and wedge it between two of the wheel studs then figure a way to get that to not move.
I would suggest though that you find a friend who has an impact wrench, or buy your own and a compressor, and get a 36mm socket from autozone and go to town with the wrench set on kill. thats how i get mine off and back on.
yea i tried wedging a broken adjustable wrench with a kinda pointed handle into the back of the brake rotor/hub..that stopped it from turning freely but still may have 2 find a way 2 break the nut, got a 36mm and a torque wrench..pipe wont fit over the handle, so imma try 2 get a big ass 1/2in drive rachet n put the pipe on that next.
use a breaker bar and a 3 or 4 foot long pipe in preference to a ratchet, and don't even think about using a hand torque wrench. If you don't own a breaker bar you can 'rent' one at autozone.
If you had a hand-powered impact tool (the kind that is shaped like a big punch or chisel but takes a socket on the end and you hammer on and it twists the nut free) that would probably work for this scenario as well.
Really, as stated before though, a standard impact wrench, either electric or air powered, would be perfect for this task.
good luck with it.Last edited by batever; 09-14-2010, 11:50 AM.
no autozone dude lol...theres this super poop Carzone, with like universal real BS name gauges for $300 n all kinda StreetGlow shit...grilles n stuff. Wanna burn that place. We got one Goodyear that idk if its even in business, Kmart Appliances, NAPA...real shitty performance 'market'..but yea im going 2 attempt the breaker bar/pipe extension...plus the torque wrench has a wide ass plate with the readings on it close to the handle, no pipe fits on that
Originally posted by jimy View PostYour best bet and easiest way to take that off is with a impact wrench.You CAN'T Fix Stupid!
Originally posted by myblk92ex View PostThis will be the easiest way to get it off, them nuts are like 200-300 ft lbs or more(depending on how long it's been on there and who put it on). I allways use my 1/2in impact wrench. Just take the knuckle to a repair shop and ask them to knock it loose for you.
Make sure to unstake the nut first so there is no impediment to them doing it for you and you have a high chance of them not charging you a thing.
yea so that axle didnt have the correct splinage...so i found an abandoned one thats being stripped...ill hop to it 2morrow morning...the engine n tranny r gone but the knuckles n axles r there n still mounted..got my 3/4inch craftsman/pipe crowbar my rotor-jammer 36mm n flatheads/chisels/hammer to unstake the stake..
