Hey guys, how do you remove the drivers side interior door panel? I don't know where all of the screws are and what I need to do specifically. LMK ASAP
Interior Question
removal of door panel
its actually very very simple get a flat tip and a phillips screw driver. use the phillips for the two screws ones located inside the handle pocket usually where you rest your arm at, and one is behind the door handle and inside the door handle behind the level and if im correct there might be another somewhere underneath a cover you can remove with a flat tip but other than that remove the clip from the door handle after you removed the screw theres a clip that holds the bar that releases the lock to open the door take it off and than take the flat tip and carefully pry the door panel away from the door try not to put it in too far and damage your speaker haha XD good luck budWhat Do You Tell a Chick With 2 Black Eye's?
Nothing You Already Told Her Twice
if you need pictures cuz youre a visual learner like me my advice is run to your local pep boys or similar store and see if they have a haynes manual for our 90-93 accords for like 40 bucks; itll show you how to take apart the door in there. Also owning that manual as a reference is worth every penny, and will help you a lot with most other areas of CB7's
if the window regulator/motor is at fault, find a new window regulator/motor and replace would be the best option the door and the window regulator/motor are two separate things, so you could go to the junkyard and pick up just the window regulator/motor, but keep in mind those motors are probably about as old as yours were to begin with. If the price is not an issue and a new one is not that much more expensive, i'd recommend picking up a new one from somewhere, or a used one that someone can verify works well and strong, to replace them. I know eBay has a bunch, used and new. theres other places to get them too, so good luck in finding a good one!Last edited by P5ylance; 09-13-2010, 11:44 PM.
Originally posted by P5ylance View Postif the window regulator/motor is at fault, find a new window regulator/motor and replace would be the best option the door and the window regulator/motor are two separate things, so you could go to the junkyard and pick up just the window regulator/motor, but keep in mind those motors are probably about as old as yours were to begin with. If the price is not an issue and a new one is not that much more expensive, i'd recommend picking up a new one from somewhere, or a used one that someone can verify works well and strong, to replace them. I know eBay has a bunch, used and new. theres other places to get them too, so good luck in finding a good one!
When removing the door trim (once you have ensured all the screws are removed) pry from the bottom corners (pulling outwards).
Use only your fingers (no flat head screw drivers or pry bars). Your fingers will be strong enough yet gentle enough to not dig or scratch the door trim and door paint.
Note: Don't pull too far and hard (especially near the courtesy door light - if equipped), as there is a wire leading to the light which must be removed.
Also the wires to the power window control switch and power mirrors must be removed while your holding the trimming. Have a flat head screw driver handy as you may need it to pry the wires off with the only free hand you have.Rides:
Accord
92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
96-AUDM-2.2 VTiS- Heather Mist
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" Motegi Edition - Silver
95-JDM-SiR "Transtop" Daytona Edition - Silver
92-JDM-SiR "Transtop" - Black
Prelude
91-JDM-Si-4ws "Si States" - Phoenix Red
91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
