on my 91 accord there is absolutely no gas goin to my engine. i disconnected the hose and my friend cranked the car and no gas came. i replaced the fuel pump and the main relay. still nothing. wen i try to crank it i can hear and feel a click sound from the relay. the fuel pump is from a car that was running so it has to be good (?). i got a test light and tested the fuses inside the car but i dont have the cover so i dont know which ones suppose to have fire. there were a few that didnt. man i had this problem for a long time now. im thinkin bout sayin fk this gd honda. what else is there to do???
91 accord no fuel
If you used an old fuel pump, it may have gotten damaged when you swapped it into your car. If you're going to go through the hassle of replacing a fuel pump, it's best to just use a new one. It's difficult to diagnose a problem when the parts are questionable. Hell, even new parts are occasionally bad right out of the box.
If you're getting no fuel through the line, then the potential problems are fairly few. Bad fuel pump, clogged fuel line, clogged fuel filter, or bad main relay. That's it. If you got fuel to the line, but the injectors weren't firing, then you'd have the injectors themselves, and the injector resistor box to consider. At least by checking the line directly, you ruled out those parts (for now, anyway.)
Do you hear the fuel pump kick on when you start the car? If so, then the most likely issue is a clog. If you hear the pump, then the main relay works, and the fuel pump most likely works (noise doesn't always mean it's pumping, though...)
...and be sure there's plenty of gas in the tank. I've seen people do dumber things.
