Hello... Noob with a couple of questions
    let me introduce myself. name is Ron and am new to the Forum and Honda's, at least working on them. I have 2 Accords. a 1991 and 1992. The 1991 I bought for $400. and is bone stock and runs ok but needs some work.
    The 1992 was given to me by the same guy I bought the other one from. Doesn't run at the moment. No spark, he thought the timing belt broke and didn't want to mess with it. Turns out to belt is ok.
    Question is with all the research I have done for the 1992 motor it should have a F22A1 but has a F20A SOHC motor in it which as far as I can tell was not factory installed in the US. my guess is motor must of been swapped at one point. Numbers on motor are F20A 1873225.
    Since there is no spark, all electronics work by the way, motor turns over ect., should I get another whole distributor or just try and change the igniter or something else? Also took the old distributor out and no numbers on this thing. What are the correct numbers for replacement distributor for an F20A?
    any insight would be appreciated.
    Thanks
    Ron
    Thanks
    Ron
    dont quote me, cause i dont know the specific differences (if any) between the f22 and the f20 dizzy. but i think youd be able to swap enough usable parts from the dizzy on your running car to diagnose the dead one. maybe even swap the whole thing.
    like i said, im not certain but it may save you a few bux.
      Ya, I have not a clue between the differences, if any between the F20a and F22a1 either. Looking at the sticky in this forum seems most everything is the same as far as specs, from what I looked at. I just am not certain that the distributors are the same and would be able to diagnose the F20A with an distributor off my F22A1.
      anyone??
        If its not turning over all the way check the battery and starter wires and grounds. Then if not starting try takeing your distrib to a parts store and have them test the electrical components. mine did the same ting and they tested it and i had to end up getting a new distrib.
          Great Idea! Thanks
            Update.
            It turned out to be a bad coil. Easy fix.
