Few weeks ago as i was doing the timing and head gasket with 92smokeaccord while putting the rocker arm assembly back on two bolts and chambers got stripped, though i managed to rethread the bolts and tap one of the chambers the other one is pretty much done, there is no surface to tap. Wondering if i can JB weld the chamber and re-tap it, dont see any other solution besides getting new head or new motor witch i DONT want to do right now and winter is coming and i need my ride.... any alternatives?
ALSO if/after i JB weld the chamber what size drill bit do i use? the bolt is a M8x1.25
i got this from a chart but still dont get it
M8x1.25 0.3150 8.0000 ~21 1.250 6.8 mm
and id like to say thanks to 92smokeaccord for stripping my bolts ....btw bring me your spare bolt next time you come over
