sway bars question
    sway bars question
    any opinions on which companies makes best sway bars for our cars? the suspension techniques one is the easiest to find (green ones) and then comes the eibachs and a couple other companies. i was just looking into them because i run canyons with my buddies a lot (GMR and trabuco canyon, if youre in oc you might know those ) and i wanted to reduce body roll. any info would help.
    Thanks in advance!
    progress
      so progress is definitely better than everything else?
        Just saying its an option. I like mine. What would you consider "better"?
          better i guess is a relative term for this isnt it because sway bars may be stiffer or softer respectively and some may work better with certain suspension set ups better than others correct? i was just wondering if there was one that was either of better quality make, fitment, and performance than the other competing brands.
            You really need to check thickness, material used, ect. The best material used would be chromoly steel because it will flex but it will return to the original shape. Most bars which are mild steel will flex and stay distorted after a while.
            Call me Travis.
            2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
            1992 Accord LX ~ "Smoothie"
            1991 CRX Si ~ Hellion
            1989 GMC S15 ~ Oldie
              good to know! wonder if i could get that kinda info out of the manufacturer without them giving me some sorta bs about a proprietary secret ill have to try when i get some free time.
