Milky Tranny Fluid
    Milky Tranny Fluid
    Hey wats up guys, I have a 92 Honda Prelude that is automatic and I just got done with an engine swap. I noticed when I checked my tranny dipstick, that the fluid was looking milky and white, so I drain the fluid it and it looks like chocolate milk..Im thinking its the tranny cooler thats causing this. Im hoping that I have suffered no transmission damage and Ive caught in time. Any thoughts on what it might be? Thanks in advance.
    www.PreludePower.com
    BB SQUAD MEMBER #28 V.2
    does your car overheat? sounds like coolant is mixing with the atf
    COUPE K24
      The tranny cooler would be my best guess as well. That's the only way the transmission fluid comes anywhere near coolant... unless you somehow got water in there.
      Your best bet is to replace your radiator, or run an auxiliary tranny cooler, and bypass the one in the stock radiator.
      The car wouldn't overheat unless coolant levels get too low.
        dam man, an to think the car was gonna be running for at least a week or 2. now this.
          Ok I guess Ill be getting a new radiator..I also checked the coolant and its still green so I dont see any sign of it mixing inside the cooling system.
            Yeah, its an utter disappointment. I thought Ill at least make it to the Prelude meet but now thats in speculation. My biggest worry is that it fudged up the tranny and Im crossing my fingers that it didnt..Worst case scenario is Ill just get a JDM H22 tranny.
              You do realize that when you "drain" the transmission using the drain bolt, that you aren't even draining out half of the transmission fluid. The majority of the fluid is still in the torque converter. You will either need to flush out transmission or just refill, drain, refill, drain, etc, until you have 100 percent transmission fluid.
                Ok, so i dont have the machine to do the flushing so how would I go about doing this? Fill, start it, and drain until I see straight tranny with no discoloration and repeat if necessary??
                  That would be the way to do it.
                    Yep...sorry, wish there was an easier way short of removing the transmission. But that is actually the best way. Many people report transmission problems after getting it flushed.
                      did u drive thru high water?
                      (129)Transactions and counting
                        for sure you got water mixing inside with fluid. hope you get this fixed, and good luck
                          Na bro, I did not drive through any high waters.
                            Refilled it up today and drained it and its still straight chocolate milk...:/.....gonna keep at it and buy some more tranny fluid..
                              Have you changed the radiator or bypassed it ?? I think it was pretty much agreed that this is where the water/coolant was coming from.
