i putting seafoam in your gas tank the car runs better, but how does it run when u directly put it in your engine, how does that mix with your oil? and is really better 4 your car? my 1993 10th anni has 265,000 just trying to give the old girl some catnip? any advice? thank u.
seafoam question?
This topic is closed.
From what Ive read about it, It is used to clean carbon buildup from your engine, clean your injectors, clean your oil and a whole lot more. Youll probably need a few cans but first fill up your tank completely and add seafoam. Run your car to "e" on that one tank and dont fill up at all. More gas will dillute the seafoam.
Please stop by a local parts store and read the can. You do not use a whole can in the gas tank. You do not just add it to your oil and drive on it.
You use 1/3 of the can in the gas tank, you use 1/3 of the can to clean the intake out by using the brake booster vacuum hose, you use 1/3 of the can in your oil just before changing the oil.
You should look it up on youtube as well, there are several videos on how to use seafoam.
Since you don't want to take my advice and check youtube for yourself, here it is to get you started. Merry christmas. If you don't know where the vacuum hose from your brake booster to your engine is, I don't recommend you attempt to do this. Get someone who knows about cars to help you.
http://www.youtube.com/watch?v=vRAV5ln5cUc
Originally posted by 4U2H8ME View PostPlease stop by a local parts store and read the can. You do not use a whole can in the gas tank. You do not just add it to your oil and drive on it.
