eassiest way to change oil pressure switch?
    i want to replace my oil pressure switch i know its above the oil filter, whats the easiest way to remove it?
    btw my car has oil but the oil light stays lite on my dash
    So i guess you have the f22a1 single cam in your cb i used to take off the oil filter and then take the socket and take it off that was a good way for me
    92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
    91 cb9 wagon
      i did mine straight up . It is not necessary to remove the oil filter. Just jack up the car securely of course and you have plenty of space to manuever. Once you are under the car you will see plenty of space on the left of the oil filter to put your ratchet through . just use a deep socket
