injectors
    injectors
    when one of the fuel injectors gives out, is it easy to fix? curious to see if its worth it. i dont know too much about fuel injectors and such.
    Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682
    My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8
    Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7M
    Well to replace is easy.... i bought 1 for like 50 bucks from o'reilly's.
      before buying new injectors i'd get some lucus fuel injector cleaner. that can fix the problem sometimes. usually the injectors gets clogged up and some cleaner can do the trick
      the daily: 2001 VW golf 2.0 (tom01golf on local and vw forums)
      the project: f22a1 400-450whp (build thread to come when things start picking up)
        I would try the fuel injector cleaner first just to see if that does anything. Have you checked your fuel rail and everything leading up to the injector?
        '92 CB7 H22a M2B4
          i had some that were stuck and i took them out and soaked them in carb. cleaner it free'd up nicely.
            We've soaked injectors in a mixture of sea foam and carb cleaner and they've freed up, make sure you take the o rings off first though or replace them.
              You could always grab some form a junkyard, too. New is always better, but junkyard injectors are cheap, and most likely no worse than your remaining ones.
