so the sweet smell and the white smoke could just be the coolent burning caused by a crack in the head?? And the leak of oil in Spark plugs could be cuase by the lower rocker arm seals? Leading 2 burning more oil and coolent than usual??
f22a6 with vtec head
There should never be a "usual" level of burning oil or coolant. Any burning is bad.
But yes, those are definite possibilities. I guess replacing the head isn't a bad idea. Replace it with a new F22A head. Before you swap that new head on, make sure the block and head are completely straight. If they're not, they'll need to go to a machine shop. Replace all seals on the new head. Once the old head is off, you can inspect it to see if it's damaged. If it's not, it'd be a great performance project. Put some money into it, and put it back on... some good headwork on an F22A head can easily get you to H22A power levels.
