My heater is not working
    my heat is not working and my rear defroster is not working ether my car took a pretty good hit on the climate control when the tree feel on my car like . i swift the climate control from cold to hot and nothing happens . so can u guys help me here is getting cold in jersey i need to get this thing working or i will freeze my ass during the winter
    EDIT : just checked all my fuses they seem ok so anything else ?
    bump anybody ?
      does the fan blow just cool air, or does the fan NOT work at all???
        is blowing cold air like i never change the temperature to hot
          Maybe your heat selector knob thingy isn't working right. I've had it happen to me before.
            but the rear defroster is not working too and i thinking on changing the climate control
              Check your coolant level first... If its not at the right level, your heat wont work right.
                ok i will let u know tomorrow
                  ok i will let u know tomorrow about that
                    coolant lv is good maybe is the thermostat ?
                      It's not the thermostat. However, the switch that opens the heater core to coolant may be malfunctioning.
                      I'll look in my shop manual for you.
                        the heat works likes this:
                        first you have to have sufficient coolant levels....ONLY way to check is the bleeder valve located on the head...water outlet pipe. could be full under the cap but still have air in the lines.
                        second, the thermostat needs to be working...if it is stuck open you will have little heat...if it is stuck closed...well you will overheat. However if yours is stuck open, it will still heat up so long as you are not driving.
                        Of course if one or both of those were a no go your temp gauge would let you know. (air in the system leads to temp gauge shooting up, and then going down when you increase rpms)
                        third there is a temp control knob. It connects to a temp valve, it is located in line on a water line going to the heater core. If there is a problem with the valve it could cause and increased amount of torque to be used to turn the knob leading to the knob breaking. Or the valve could be defective to where you can not adjust the temp.
                        Usually this is the result of water level. You will need to get the car to operating temperature while NOT driving the car. Turn the knob all the way to heat (this will allow hot coolant to flow into the heater core) then open the valve, any air will be expelled.
                        If that is good, then with the car still sitting still watch the temp gauge...even if the thermostat is stuck open it should go up ALMOST half way...UNLESS the air temp is very cold where you live...still it should rise...if not...let us know.
                        If it raises when sitting still but drops when you drive...thermostat stuck open.
                        But that only addresses the issue of the coolant flowing properly...you may still not have heat. So post back and let us know.
                        ____
                          Sounds like bjcammerx has this one down cold in general.
                          However, since you took a direct hit from a tree on the climate control, something could be broken or broken loose in that unit.
                          This may be helpful:
                          photobucket is possessed, I cropped this photo but it keeps downloading this:
                            i have a heater problem my heat control valve thingie near the fire wall is stuck a few ?s i have
                            1. does ne one know wat the name of this part is i cant find it on auto zones web site
                            2. does ne one know the best way to remove it do reach up from the bottom of the car or take the intake ducting aloose reach down to it ?
                            the car has been sitting with a cracked rad for a year so i think mine is frozen
                            Better to have and not need , than to need and not have!
                            Life is simple make choices and don't look back
                            MRT http://cb7tuner.com/vbb/showthread.php?t=173251
                              If you have ever put any kind of "stop leak" in your radiator, your heater core is most likely clogged. That is very often the cause of no-heat issues.
