Who on this forum has the highest HP for a N/A F22B DOHC
reason im asking is my F22B is being rebuilt as we speak with 11:1 compression pistons, the head is being shaved so in the end it will have a little higher then that. also getting the balancer shaft deleted.
the head is a h23 head, its recieving a hot tank bath, 5 angle valve job and new seals.
the cost is at 2858.57(i didnt list everything that is being done)
Im coming across about 6 grand soon, and am trying to put together a parts list too squeeze as much N/A power out of this engine as possible.
heres what i have in mind for now.
Skunk 2 Light weight cam gears
Delta stage 2 N/A camshafts
stage 2 KMS valve train rebuild kit w/ block gaurd
Blacktrax modified stock h23 IM with spacer.
sikky Heat resistant IM gasket
Blox 68 mm TB
Precision 400cc injectors
walbro 255lph fuel pump
Chipped p28 tuned with s100
What do you guys think i should expect in terms of HP if i added these things. and if its possible could you point me in the direction of some some other N/A builds, F22B DOHC or not. just so i can compare.
Blox 68 mm TB
