i have a 90 cb7 i replaced the clutch,pressure plate,master,and slave an still got no pressure and i bleed it for maddd long can some1 help
no pressure in clutch
actually thers a trick i learned.....
1. u need a extra guy
2.1 guy pump clutch
3.hold the presser plate fork in as hard as u can so when he pushes the clutch down it pushs the slave cylender and ur hand out.
4.pump 10 times while doing this/\/\
5.bleed normally
what this does is it will build presser faster than normal.i got mine done with no air in 10 pumps.
the reason why it gets so much air in the system is when u change slave/master theres no fluid unless u bench bleed it first.
and last but not least check for leaks.
Originally posted by 92smokeaccord View Postactually thers a trick i learned.....
2.1 guy pump clutch
5.bleed normally
Seriously, I doubt this is a hydraulic issue at all.
Try this:
Put the front of the car up safely and then start the engine. Ask a friend to try to put the car in reverse afteryou press sideways on the clutch release fork with a stick or something in the same place and direction where and in which the clutch slave cylinder pushrod pushes. Yell "switch" to him to have him move the gearshift lever to reverse without pressing on the clutch pedal. After he yells "ok", release pressure on the release fork and see if the wheels start to rotate.
If he's able to move the gearshift lever into reverese and then the wheels start to move in reverse after you've let go of the release fork, you know that the problem is before the clutch release fork--so the problem is the hydraulics.
If he's not able to move the gearshift lever into reverse, then the problem is not with the hydraulics but something at or after the clutch release fork.
I say ask him to shift into reverse just in case the car drops--the car will move away from you, not over you.
This will test whether the problem is in the hydraulic system per se or in your installation of the clutch components.Last edited by batever; 09-04-2010, 03:50 AM.
I'm quite sure that my issue is hydraulic. I changed all the clutch components. This wasn't my first clutch install (though the first time doing the hydraulics), and I had help from half a dozen knowledgeable members of this forum. I have full pedal travel, currently with partial pressure, and I don't believe the release fork is moving at all yet.
The procedure that 92smokeaccord suggested is something that my friend's dad did. I haven't tried that yet. It worked on my friend's CB, so maybe it'll work on mine!
Originally posted by deevergote View PostI'm quite sure that my issue is hydraulic. I changed all the clutch components. This wasn't my first clutch install (though the first time doing the hydraulics), and I had help from half a dozen knowledgeable members of this forum. I have full pedal travel, currently with partial pressure, and I don't believe the release fork is moving at all yet.
