I Got Oil in My spark Plugs??
This topic is closed.
    i got oil in my spark plugs ive changed the vaulve cover gasket like 5 times nd the spark plug tube gaskets or wat ever u call em.. but theres still oil in em.. Wat can b the problem. could it b just the head gasket or is it more than dat???
    how much oil is in the hole? when you changed the valve cover gasket, did you put the sealant on the gasket?
    the daily: 2001 VW golf 2.0 (tom01golf on local and vw forums)
    the project: f22a1 400-450whp (build thread to come when things start picking up)
      yea. n ive done it 3 times had a shop do it onec nd also a friend tried it.. n still leaking. im thinking is the head gasket cuz there a sweet smell coming out the exhaust n white smoke.. but ive bn told i could b something else i got the head gasket do i need anything else 2 change it? n does any one have a DIY for it
        Could be the lower seals leaking. Was the oil on the bottom of the plugs?
        The white smoke and sweet smell makes it sound like it is the head gasket for that. Are the spark plugs steam cleaned?
          were r the lower seals at.. im still learning..
          the spark plugs a full of oil.. wat u mean by steam cleaned.. like shiny
            If you're burning coolant (which you clearly are if the exhaust is sweet) then the spark plugs will be clean at the tips. You have a blown head gasket.
            There is a DIY for the lower tube seals in the DIY section of this site.
              yea da tips look like new.. but do i need 2 do the lower tube seals 2.. r those the ones under the roker arm.. if is the head gasket do i need anything else apart from the head gasket is there any othere gaskes or seals on dat????
                did you get the little kit
                did you have any extra parts
                  Please use your big boy words. Nobody wants to tell someone how to fix their engine when they can't even spell "what" and "that" correctly.
                  Your motor is going to have to come apart. Pull the head off for the head gasket, and do the lower tube seals at the same time. Yes, they are the ones under the rocker arm assembly.
                  I love how you have another thread going asking how to make power with this engine... that thing is about to explode, and you want to do performance modifications to it? You have a lot to learn, kid. A lot to learn. I hope you have money to burn.
                    Head Gasket, intake manifold gaskets, exhaust manifold gaskets, valve cover gaskets, valve stem seals, plug seals, grommets, camshaft seals.
                    And yes if the plugs seem new/cleaned I would say head gasket.
                      iight First off all i cant write how i want im 22 not a kid i just move down from Puerto Rico bout 5 years ago im still learnig my english but i do know enought 2 tell u FUCK U if u dont like it... n yes i got some money 2 blow i own a business so i get my money.. n i got the parts 2 fix the head gasket problem im just making sure that could be my only problem. So if u dont like the SHYT i say dont reply 2 da post. n have some respect i dont take shyt.. iight
                        Do you enjoy posting on this forum? Because you DO realize you're very close to being banned, right?
                          do You Enjoy Posting On This Forum? Because You Do Realize You're Very Close To Being Banned, Right?
                          I Was Just Trying To Help Deeve. Just Trying To Help. I Hope You Know Im Going To Drive My Cb Off A Cliff Because You Hate Me.
                            i dont give a shyt
                              Ok. That's fine with me! Good luck.
