I got a 92 cb7 with an F22a6 i wont more power than wat is got 4 cheap wat can i do
How 2 Make an F22A6 get more Power 4 Cheap
aftermarket camshaft, lighter flywheel, h23 or h22 trans for better speed, theres alot of things to upgrade that motor.
no..bassically what you can use from a h22/23 is the intake manifold and trans..if im not mistaken
#3MR 91 coupe: http://www.cb7tuner.com/vbb/showthread.php?t=186456
#2MR 90 sedan: http://www.cb7tuner.com/vbb/showthre...51#post2867651
#1MR 93 coupe: http://www.cb7tuner.com/vbb/showthread.php?t=176343
here's a thread that is from a few months ago...
http://www.cb7tuner.com/vbb/showthread.php?t=162658
btw... the search button still works great. also, there's a better way to search the site using google, but i can't remember exactly how.
Originally posted by rob_is_legend View PostWeight reduction is free. who needs air conditioning, power steering, windshield wiper fluid, cruise control, carpet, or seats anyways?
remove your balance shaft belt, it will improve some HP and faster RPM's...
the less rotation mass there is on a motor the more HP it will release.
there alot of hidden power on these motors bro.
Originally posted by matapista View Posttried that weight reduction b4 is 2 hot in fl 2 have no ac i already got rid of the cruise control n da power steering n the washer fluid thing 2.. but cant let go of the sets
Originally posted by pedroalcala View Postremove your balance shaft belt, it will improve some HP and faster RPM's...
XTD will blow up and damage your car. I know from experience.
Kid, don't cheap out. Do it right, and do it ONCE. You're trying to do things on a budget, and I can tell already that you're looking to buy the cheapest shit "performance" parts that you can to make more power.
First, maintain and restore your engine. It makes about 120whp in stock form. Chances are, at it's current age and condition, it's making under 100whp. Replace seals and gaskets, replace your ignition components, replace sensors, set your idle and ignition timing properly (all this info can be found in the "technical" part of this forum) You will regain any lost performance.
Next, learn about the parts you are replacing. Certain parts seem like a good idea, but are really just a waste of money (like a cheap header, or "straight through" cat from ebay). Learn what parts you need to achieve your goals, and learn the difference between the cheap and expensive brands. Get only the things that will actually help you reach your goals. Don't buy cheap shit. Don't spend money on parts you don't need (do you NEED a new clutch? you certainly don't need a "performance" clutch until you're making over 200whp... you'll only be wasting your time and money otherwise.)
And finally... stop typing like you're 7 years old. You will be treated like an idiot kid if you present yourself as such.
Originally posted by HondaCB7sb View Postno..bassically what you can use from a h22/23 is the intake manifold and trans..if im not mistaken
And deever, I used proper punctuation and spell checked this before posting!90 Accord Ex, F22A4. Slight fire damage.
Originally posted by H.M. View PostSo if I have a F22a4, and I'm planning on putting on the a6 intake manifold for more oomph, I could just skip that and go directly to the h22/23 intake manifold for even bigger bang?
Also, the H22/H23 throttle body will be necessary. The F22A throttle body will not bolt on.
