Okay, I ordered caster shims today and I wanted to know if anyon has had any experience installing them and how difficult the job is, and/or what tools I may need for the job.
caster shims advice
Originally posted by deevergote View PostWas your car hit? The caster on our cars is not adjustable, and therefore should not be able to go out of spec. I've never in the 7 years this forum has been around heard of anyone using caster shims on their CB.
Originally posted by Westron View PostYou think I'd oder caster shims if I didn't need them? apparently you have no good advice so I'd appreciate if you'd take your vaste knowledge somewhere else
I had never heard of "caster shims" being used on CB's. Usually people are meaning shims used for camber on the UCA's.Call me Travis.
2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
1992 Accord LX ~ "Smoothie"
1991 CRX Si ~ Hellion
1989 GMC S15 ~ Oldie
Well it has been off since the winter but it didn't wear my tread too bad so ive neglected to get it fixed. I work at an auto parts store and found caster alignment shims so I ordered them. I think these are to be used lile the washer trick for cheap camber adjustment. I had thought about using washers before to offset the upper control arm and give me a caster adjustmwnt but never got around to doing it. Just seeing if anyone had experience with this stuff
Originally posted by ATS666 View PostI have done caster adjustments on 5 or 6 cb7s, most people never want to spend the money.
2 of the cars were mine.
Is your car drifting to the right?
What's your caster readings? The shims only correct alittle bit
Deev
The caster shims are washers that go on the radius rods.
Originally posted by Westron View PostThat sounds right. You've used the shims before with success? Where are the radius rods located?
Front crossmember to lower control arms can't miss them
Originally posted by Darkcloud View PostFront crossmember to lower control arms can't miss them
