car cut off while i was driving. turns over but dont crank. if starting fluid is sprayed in the air box it will start but not for long. maybe 5 seconds. is this a fuel pump problem and anyone know the correct way to change a fuel pump? 91 accord
fuel pump?
a good tip, take the fuel line off the car , then have a friend cut the ignition on and if she squirts , the pump is not your problem. but i agree , its more than likely the main relay. mine took a crap and thats what is was . good luck man.
Originally posted by BLUBB2 View PostCheck for fuel, although the main relay is most likely culprit.Originally posted by stretch JDM View Posta good tip, take the fuel line off the car , then have a friend cut the ignition on and if she squirts , the pump is not your problem. but i agree , its more than likely the main relay. mine took a crap and thats what is was . good luck man.
Most likely it's the relay, as you've been told. It sits behind the dash to the left of the steering column, and above the cruise control box if you have CC.
