drops?
    drops?
    ok so, i decided that i wanted to go a little lower then my current drop.
    i want to drop my cb about a inch more. should i cutt or just buy new springs?
    help?
    Cutting your springs would be incredibly stupid.
    I hope you're on new shocks that are made to handle a drop.
      well first things first you should properly inflate your tires. front one looks low on air.
      second DO NOT EVER cut your springs!! very dangerous!!
      if you want to lower your car then do it right. buy the correct shocks and springs. and a camber kits for all 4 corners.
      just cutting your springs or even just using new aftermarket springs with stock shocks is a recipe for disaster.
      Parts For Sale
      BIG Thanks to HondaFan81 for all your help!!
        mm, im on neuspeed springs and new stock shocks already. what should i go with in order to to have the tires line up with the fenders?
          New stock shocks are a bad choice. They aren't made for a drop. The very least you should get are Koni STR.T.
          How long have you had that stuff on there? If it's fairly new, it will still settle some. Are they Neuspeed Sport or Neuspeed Race springs?
          Going too low will thoroughly compromise the integrity of your shocks... making the ride uncomfortable, and a bit dangerous. Especially where you're from!
            Koni (Neuspeed) Yellows with Ground Control Coilovers, and ingalls camber correction kits for the front and back will get you as low as you want to go properly and safely. Better start saving.
              had them a little over a month. lOl, i guess its time to start filling the pigie bank. thanx guys
                whats your current drop?? see i like 15 inch wheels, i have 205 60 tires on, i want a 2in drop ONLY, i think it will suit my fat tires nicely
                  I agree. Too low just looks broken to me. When I see a slammed car, I expect to see a doofy looking kid with a sideways hat driving it. I don't take them seriously. Unless, of course, it's a show car... those can pull it off.
                    lol
                    Honestly man your front lip is already probably only like 4-6 inches off they ground. Your up in NY you sure you want to wind up tearing your front lip off and driving over it?
                    As far as cutting the springs question. It is NOT recomended for several reasons. It can however be done if you understand the consequences. First tings first is the actual fit of the spring on the strut. If say you have a spring that is the same width from top to bottom then it would be as easy as cutting off half a coil or maybe a full coil. If you have a spring that say has one very small coil where it mounts onto the strut and then widens out then it wont be possible at all.
                    If you can physically cut the spring and have it fit correctly this will in effect change the spring rate of the spring, making it stiffer. Some people try to overcome this by cutting the dead coils of the spring found at the top of the springs. Dead coils are the coils that just sit on top of each other. It actually works too.
                    If you dont already have the tools and the know how to cut the spring properly a shop might charge anywhere from say 30-100 bucks with the springs off the car. Might just want to buy new springs at that point being your trying to not use any money.
                    Now after all this talk of getting you lower and increasing the spring rate by cutting springs the main problem remains not only for cut springs, but any lowering springs in general. You need the right STRUTS to do the job.
                    Only thing that can handle anything at and over 1.5 drop is either konis or revalved bilsteins. Either of which is going to be alot of money when compared to springs. 500 or so.
                    So if you dont have enough money right now for new springs, you certainly wont have enough money for struts that can control these springs.
                    Suspension.....shes expensive to get right.
                      lOl, im fairly new to the cb performance so im glad you guys are puttin me on. you did make a point tho, i am in ny and my lip is sittin 4" off the ground as is. with my current drop, i can barely make it into my boys garage with out scraping. so i think i'll just stick wit wat i got for now... i must say tho, i love the effort everyone puts in to help eachother out. you guys are great, this site is great! lOl. thanx.
                        i live in southern cali and they have a law around here about how low you can go
                        i got pulled over the other day and the cop asked me how low my car was, i said i dont know
                        so they measured it and they said the headlights must be 24" from the ground, mine were 22" but he let me go for that because he gave me a tint ticket anyways
                        they said its a safety issue, i say its a bullshit law for them to make more money
                        90 accord lx
                        form > function
                        Member's Ride Thread
                          That is BS. I feel bad for all the Cali people..emissions, tint and now 24" bullcrap?? I have never heard of such thing. I understand the safety issue on slammed cars, cause an EF hatch slammed is way lower than our CB's. Whats the next law....how many inches in diameter our Dookie pipe can be? I'd tell them to F off and go get it registered in Arizona.
                          '92 CB7 H22a M2B4
                            What happens in CA usually happens in the rest of the country, where laws are concerned.
                              True, but in SC there is no inspections what so ever. NC..I just have a safety inspection and that goes for all OBD I cars in a populated area. If you have an OBD II car and live in a rural area, you don't have to pass emissions. Only cities and OBD II cars require the sniffer. Florida got rid of inspections if I'm correct, so they can have 2% window tint and open header...well maybe not open header, but other stuff that some states can't pass.
                              '92 CB7 H22a M2B4
