Hello my name is afief and i have a 90 accord 4dr H22a. I recieved a 90 accord from my uncle as a deal if i could start it and get it running i can have it. The problem was an ignition fuse, it was blown. When i recieved the car it had oil leak water pump leaked vtec didnt xover and the wiring was a mess. I fixed all the issues finally and chipped ecu with an H22 base map. Now the car isnt revving past 6k. I changed the dizzy fuel filter, fuel injectors,egr, and 4 ecus. all i have is cel for o2 and i changed. Finally i removed my exhaust and it fixed the problem. I am amazed at the power and feel of this car. The only problem i have is my oil light is blinking
my H22a
yes. I loosened the front collector below the mainfold and the car was running alot better.The idle improved alot also and runs smoother. I am going to hollow out my cat.I have alreday put in new piping 2 1/,but i replaced the cat last year for emissions and im very surprised its already clogged.
the blinking light sounds like the oil pressure sending unit, it is a high pressure sensor and if it is leaking then it isnt reading the pressure it should. My f22a had that same problem, and I replaced it and it fixed the blinking light problem, but it later destroyed itself ( I think bc i lost oil pressure due to a bad pump or clogged pickup, I havent tore it down yet )
