ok so before my s light would come on solid and my car would go into "limp mode" after doing some searching on here i tried to pull the codes from the tcu but i couldnt find the plug i looked for 2 hrs and i read on here that most of the time its the tcu that went back i have a 90 accord dx and i got the tcu from a 91 accord ex the car shifts fine and feels alot stronger with this tcu but my s light is blinking now is this normal ?
s light blinks after i changed the tcu
If the light is on, it means there's an error code. There is a plug, a blue plug, under your dash on the passenger side. If you read the "sticky" thread at the top of this section, you'll even find pictures of the location of it.
The light is still on because it's not a bad TCU. It's a GOOD TCU that is telling you that something else is broken.
Originally posted by deevergote View PostThere's no need to take out your glove box. It's lower than that, to the right.
Does your ECU have an LED on it? If so, it may be an early model, and MIGHT not have that plug... I have yet to confirm that. If that's the case, I'm not sure how to read a TCU code, unless the TCU has an LED too.
Look behind the passenger side front cowl trim, or behind the carpet in the corner behind the trim. See the cluster of wires in the photo? It should be near those.
Either way, the trim can be removed to pull more slack in the cable.My pictures/photos will return soon...
Originally posted by deevergote View PostThey're only on 90s... and only early model 90s, becuase I know a few that don't have them.
I bet an LED could be soldered onto all the ECU and TCU boards to activate the spot lens feature.My pictures/photos will return soon...
If the TCU has the spot lens, then that's where you're going to see your codes, I believe. Reinstall that TCU, as there is probably nothing wrong with it. See what the codes are by counting the flashes of that light, and fix those problems. If it still works poorly after you know you fixed those things, THEN try the new ECU.
Yep...my 88 Prelude (auto) has the LED's built into the cases. You don't need to jumper a plug to read codes. There is a service plug under the hood that when you jumper it, you can read the ECU codes through the Check engine light, but it's main purpose is for using a timing light to set ignition timing.
Originally posted by dano28 View PostYep...my 88 Prelude (auto) has the LED's built into the cases. You don't need to jumper a plug to read codes. There is a service plug under the hood that when you jumper it, you can read the ECU codes through the Check engine light, but it's main purpose is for using a timing light to set ignition timing.
