i was passing somebody yesterday for going 35 in a 50 and i downshifted from 4th to 2 second and punched it. then i shifted from third and the rpms went up and i wasnt going any faster. and i smelt burning and thought it was the clutch. it doesnt do it when i acclerate slower. idk what it could be. HELP!
Clutch Problem?
You are correct... your clutch was slipping. It's time to repalce it.
I suggest an Exedy OEM or "Stage 1" clutch. Don't do what half the kids on here do and buy some fancy "Stage 3" performance clutch for a car that's putting down 110whp... ESPECIALLY a cheapie "performance" clutch that will actually perform worse and have a much shorter lifespan than an Exedy!
Originally posted by deevergote View PostYou are correct... your clutch was slipping. It's time to repalce it.
That depends on your abilities, facilities, and tools.
If you have a garage, a good jack, jackstands, a proper set of hand tools, access to a store for special parts (such as the 36mm hub nut, or a ball joint puller) and the ability to use them... then it's not too hard. I've done two clutch jobs with help from friends, and I hardly consider myself a master mechanic. It's MUCH easier with at least two people, though... at least when it comes to removing and replacing the transmission. It's quite heavy, and must be wiggled into place.
Originally posted by deevergote View PostThat depends on your abilities, facilities, and tools.
