my cb sputters when i put a little gas to it idk what the problem is? idk if its the fuel filter thats clogged or the injectors any help from you guys will me out alot thanks
car sputtering
what exactly do you mean sputters? will it accelerate after say 3k rpm? or is it really slow to accelerate everywhere?
could be fuel filter like you said, or egr ports need cleaning, or you need new air filter. i doubt the injectors are clogged but they could be very dirty.Parts For Sale
BIG Thanks to HondaFan81 for all your help!!
my car was fine til 3500, then i step on it and my rpms will climb reeaaaaaaaaaal slow, then out of no where it will shoot up, hasnt done it since, but i think imma need a fuel filter soon.
its about 15 with tax. i think thats alot of money**Blk Housed Slut Crew Member #1**
I would do the cheap trouble shooting items first.
Check/change air filter
Check/change spark plugs
Check/top up tranny fluid
Switch to higher octane fuel
Change the fuel filter
Check timingRides:
Accord
92-JDM-2.0 Si- "4ws" - Cobalt Blue Pearl
96-AUDM-2.2 VTiS- Heather Mist
CR-X
88-JDM-Si- Black
CR-X Del Sol
92-JDM-SiR "Transtop" Motegi Edition - Silver
95-JDM-SiR "Transtop" Daytona Edition - Silver
92-JDM-SiR "Transtop" - Black
Prelude
91-JDM-Si-4ws "Si States" - Phoenix Red
91-AUDM-Si-4ws "Cita Lux Edition" - Bordeaux Red Pearl
91-AUDM-Si-4ws "Cita" - Cobalt Blue Pearl
91-AUDM-Si-4ws "Cita Lux Edition"- Gun Metal Grey
Is your check engine light on? Does it come on when you reach highway speeds?
My guess... You can drive normally, but sometimes it bogs. You can push through the dead spot, and it'll pick up again. The check engine light comes on around 50mph, and when you pull the code, it'll be code 43: fuel supply system. Most likely, this will mean that your oxygen sensor is bad.
If I am correct, replace it with NTK or Denso. No Bosch. Bosch is bad.
it starts to sputter after 3k rpm and if i leave it to sputter for like 5 to 10 seconds it jus rapidly jumps back to normal. it only sputters if im goin on any constant speed
bossman deev, my check engine used to come on its a code 43. i went on a 2 he drive yesterday, and it didnt come on, but when i left my friends house, it was boggin, and ill ride thru the boggin like you stated, my timin is fine, i dont think i jumped any teeth, the car runs good, imma change my fuel filter soon, along with plugs.
QUESTION- HAVING A BAD CAP AND ROTOR CAN THAT MAKE YOU BOG?**Blk Housed Slut Crew Member #1**
I'm sure it can. Anything that causes your spark to be weak could.
My car has the same bogging problem, and I'm assuming the o2 sensor is the cause... that's why I'm so familiar with this. I haven't fixed my own yet, though... mainly because clutch issues forced my car off the road before I got a chance to.
ahh ya i got it in my trunk^^ ill have to do that soon**Blk Housed Slut Crew Member #1**
question, how do you check timin on our cars, do we use a timing light and point it at the flywheel teeth.
i remember reading, some flywheels come with the timin line, and some dont, i dont think mine does, i didnt see anything of that nature when i installed mine.**Blk Housed Slut Crew Member #1**
fail on me i guess.**Blk Housed Slut Crew Member #1**
I've had this problem. How often does it happen? I only get this when the car gets hot. In the mornings or at nights the car runs fine. I've tried the O2 replacement already, that did no help. But it doesnt hurt to change out your spark plugs. I've heard from other people that own different cars to have found it to be a clogged cat. The cat being clogged will reduce your performance drasically.Do I turn left when nothings right? Or do I turn right when nothings left?
mines happens at random really, i can start it up, drive 2 blocks, and it will bogg when im on the gas, then it will go away when its warm, then come back.
its scary, i dont want it to shut off or something.**Blk Housed Slut Crew Member #1**
