The front torque motor mount on my car is cracked... has anyone filled it while on the car? letting it sit for the specified curing time of course! does it technically work?
Polyurethane motor mount filler
Originally posted by deevergote View PostThe polyurethane may leak out unless you find a way to keep it in place. If it leaks out, it will do no good!
Just remove the mount and do it the right way. It'll be less headache in the end! It's not a load-bearing mount, so you can even drive without it while it cures.
guess i'll just buy a brand new rear mount, fill it, then swap and go the next time i have access to it. (ie intake manifold/head/etc...)
I would never try to fill a mount on the car, even if you could keep it in the mount, you woud be "glueing" it in a compressed or stressed position and probably wouldnt get the full effect from the mount
http://www.cb7tuner.com/vbb/showthread.php?t=187851
sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
bought from:jokerxfn-tommi-'93cb7ex
Its also an upgrade to have solid mounts
