Repeatedly, my Honda's engine fails while driving. It has never happened at idle speed. When the engine stops my tachometer drops like a rock and the check engine light comes on, then the oil and battery light. If i turn the engine over immediately it won't start, only after it cools for a few minutes.
I hear the main relay click normally as i turn the key to start (3 times, one for each position). The fuel pump and check engine light work for 2 seconds at position 2.
Battery reads 12 volts and connections are fine, might it be a distributor or ignitions issue?
