Car wont turn on till the third try..
    sup guys, i have a little problem that's been bothering me lately. It just started to happen yesterday, I got out of work and went to the car to turn it on and it wouldn't turn on, until about the third try. Also this morning i went to autozone and after walking into my car, i turned it on the first try, but then the car turned off and I couldn't turn it on until the third try once again. The car is an auto, 122k, I just replaced spark plugs and wires with NGK brand about a week ago...ooo and one more thing, I have an auto start alarm. On Thursday, I tried turning the car on with the the remote start, it tried turning on but failed. Other than that, the car runs good and doesn't turn off. Any suggestions?
    is your check engine light turning on at all?
      nope, no check engine light.
        main relay
        To have loved and lost is better than to have never loved at all #CB7Life
          Originally posted by SoySauceCb7 View Post
          main relay
          hmm, you don't think it can be the starter?
            i would check the strength of the battery, tap the starter with a wrench, and if you notice it only does it when its hot then its prob main relay.
              this is the clue it isn't likely the starter:
              "i turned it on the first try, but then the car turned off and I couldn't turn it on until the third try once again"
              car turns itself off. that's an electrical-related problem and the main relay is a prime culprit. that or, I believe, a faulty igniter or a faulty ignition switch.
              I'd suspect the relay first.
                If it was a faulty igniter, then his car wouldnt start at all, do to lack of spark to the cylinders
                  I would check the main relay its really a visual inspection and cost you nothing,
                  Also starters and ignitors can be tested for free at most parts stores
                  When you put plugs on did u change the cap an rotor? Ive seen cars actually not start because of corrosion in the cap
                  http://www.cb7tuner.com/vbb/showthread.php?t=187851
                  sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
                  bought from:jokerxfn-tommi-'93cb7ex
                    If you want to fix the main relay (free), check out this topic, and the main topic that it points to, for pictures and instructions about how to perform the fix.
                      I did not replace the distributor cap/rotor :/
                      And I'll check on the main relay, thanks a lot guys
                        if you decide to replace either, then replace them both at the same time. pretty sure that is spec from honda.
                        also just for s&g why not have autozone or whatever parts store you have around check your battery/alternator/starter. you check check your ignitor and ignition coil yourself with a multimeter. the ignition switch could be the culprit too. that happened to me a while back.
                        Parts For Sale
                        BIG Thanks to HondaFan81 for all your help!!
                          if its not the main relay then check your timing......
                          .......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
                            My bad, i think you're right, it's probably not the igniter.
                              Just a bump to clarify the situation in case someone else encounters it.... I replaced the main relay at the time and it solved the problem.
                              Thanks guys!
