alright i have a 93 accord with a jdm h22a, motor and tranny have about60k body has 260k. owned it for a couple years now. just a couple of monthes ago it started idleing so low when i came to a stop that alot of times it stalls. also it will start up fairly good when its been sitting for around 30minutes. but say if its warmed up or i go to the convient store and come back out im not going anywhere, so ive been making sure theres a hill when i park cause i can pop the clutch and shell fire right up! SO ive been screwing around trying to get her running right and its KILLING me that my baby just aint running right anymore, so heres a list of what ive covered so far.
-cleaned out iac and did haynes checks on it/ its good
-cleaned out egr and check it/its good
-cleaned and adjusted fast idle valve/that helped it not idle so high at startup
-checked injectors, but just with the screwdriver trick/ there good according to the that
-checked the injector resistors with haynes check/ there good
-valves adjusted, and timing is dead on
-new spark plugs/ and wires, well like 5 monthes on em
-new rotor button, cleaned dizzy cap metal thingy contacts
-no aparent vaccum leakes
-t/b is clean as a whistle
-checked fuel pump, but i just listening to it and it makes noise whith key turn
-did the seafoam clean in the gas tank and brake booster today
-fuel filter is like 2 years old
-checked main relay, and did probably the worst resodering job ever, but it didnt change anything
-i took a spark plug wire put an extra plug in it and had someone turn it over and got spark
all i can think is map sensor, fuel pump, fuel relay, starter, or whole dizzy, maybe still the main relay, coil, o2 sensor?, and maybe fuel filter i guess.
BUT i really dont see why any of these would matter after the car gets hot except the main relay.
PLEASE HELP! any past expierences with this problem or just any help period much appreciated
