MAIN RELAY REMOVAL AND REPAIR (more pics)
    Since I don't have 30 posts, I will try to respond to this topic, by posting a new topic here. Hopefully the pictures link correctly for people to see.
    I have just repaired my Main Relay, and I thought that some additional pictures might be useful to anyone that still needs to make the same repair:
    Here is the Main Relay that you are looking to fix:
    This shows the Cruise Control Box that must be removed first:
    Now you can see the Main Relay, and a black plastic box that is also in the way:
    A better view of the Main Relay, and the 2 nuts that need removal:
    A typical position needed to access the Main Relay:
    The 2 nuts have been removed, and the Main Relay is hanging loose:
    The Main Relay has been removed from its platic box:
    A closeup of the Main Relay PC Board, showing damaged/cracked solder joints:
    The Main Relay PC Board after resoldering all solder joints (solder flux still present):
    The repaired Main Relay, ready for installation back in the car:
    Good write up. Im sure if you talk to a mod they will put this in the diy section when you reach 30 posts
      Will do.
      It's great to see Newcomers making such an effort. This is a great pictorial to add to the diy's
      Thanks ZonFire99
      My 5.7 LS1 Holden Ute
