CAN SOMEONE POST THIS IN THE SWAP SECTION PLEASE
ok i got a 92 honda accord
i swapped a h22a of course.
i used my stock wiring harness and i followed all the wiring diagrams to switch is over such asd the knock sensor,the vtec wiring and such.
i hooked it all up and put the battery in and it wont turn over at all
im getting fuel and im getting power to the starter cuz i took a mutimeter to it.
the main relay was humming at first which would indicate a gound problem. i looked around and found that i didnt have the thermostat housing ground on. so i bolted that on and it still doesnt start.
im not sure what it could be. im not a mechanic at all im just a body man
so basically at this point i turn the key and i just hear the main relay click
but it sounds different then how it usually would sound.
if anyone has any idea's i would be very thankfull
also if anyone would like to call me my number iis 440-265-0739
my name is brian
my name is brian
