struts and springs?
    struts and springs?
    okay i got some koni orange struts and some ebay ujustable springs my question is if they would work together?
    THEN NOW
    Yes they will work together but i would rather ride on stock springs then ebay coilover sleeves
      thts true but i dont like the tire space on stock lol!!
      THEN NOW
        The ebay springs can be dangerous... I would suggest getting quality springs or coilover sleeves. You don't want to put cheap things on your suspension. Your life rides on that! If it fails, you can lose control and crash... and it's most likely to fail when you're going fast!
        Good choice on the shocks, though. Many people try to lower their cars on stock shocks, and that's just idiotic. If you were going to cheap out on something, at least you picked the safer of the two to cheap out on!
        Don't forget you're going to need an alignment when you lower the car, or your tires will be toast in a couple thousand miles. A camber kit would also be wise, but not 100% necesary (as long as you keep an eye on the inside of your tires... they WILL go bald before the rest of the tire, and once the inside is done, the tire is done!)
        Those cheap springs will sag, throwing your alignment off after a little while. Be prepared to get reailgned every so often... or whenever you adjust the height.
          well ima see how these handle and if i dont like them ill invest on some good springs and wat are some good ones to buy?
          THEN NOW
            If you want adjustable sleeves, Ground Control.
            Springs, there are tons of good options. H&R, Neuspeed, Tein, Progress, Eibach, Sprint.
            Cheap crap is dangerous. The ride will suck, and the parts may fail. Be careful.
              tht makes sense ima get some ground control probly but gona wait cus the koni set me bak a little dont wna danger other ppl for my stupidines.
              THEN NOW
