I have a 92 EX coup. All of the sudden I am having issues with me gauges. My RPM gauge and speedometer will just drop to zero, then bounce back to where they should be. My heat gauge goes past the red line, and I know it's not getting that hot, and once my car just lost all power and died. My mechanically inclined friends thinks it a "common ground issue".
strange electrical problems
my mom had a 92 accord back in the day and one time it had a proble with over heating and the car would shut off but idk if it would do the same in your case but could be a batterie, altinator, ground problem my gages do somthing like that when my batterie is and egde of death-----------------------------------------------
''It is what it is, Do what you want''
http://www.cb7tuner.com/vbb/showthread.php?t=167905
well why not have your mechanically inclined friends look at it and see if anything is wrong with it?
it could be the VSS for the speedometer, a short in the wiring, fuses blown, frayed wires, loose grounds, bad alternator even. many many things it seems could be wrong. any more pertinent information would help if you have any.Parts For Sale
BIG Thanks to HondaFan81 for all your help!!
if i was you i would do a battery starter and charger test to check the battery,alternator and starter,very simple to do and yet you kill 3 birds with one stone...or dvom in this case haha,and from there check your wires,grounds,fuses,bt if all your needles are going cukooo at your cluster,swap your cluster wit a known good one..who knows you may need it...it doesnt hurt giving it a shot..
