fuel filter replacement
    bought a new filter but havent had time to change it yet
    first i want to know how do you relieve the fuel pressure so that i may take off the old fuel filter?
    any info?
    90 accord lx
    form > function
    Member's Ride Thread
    any info?
    just losen slowly. its not hard. under 30 mins
    2013 Ice Cream Cruise!
    VIDEO: 2012 Ice Cream Cruise
    VIDEO: 2012 Ice Cream Cruise part 2
    The single largest cruise in the Midwest!
    August 3 ~ Omaha, NE
    By 1320 Video
      i always open the gas cap but you could just turn it slow either way will work
        Easiest method: open the gas cap. Second: loostening the banjo nut on the fuel rail or fuel filter.
        -Wayne-
        310whp - 296tq
          You can also throw a shop rag over the banjo nut while you're loosening it so it doesn't spray in your face.
            yes yes yes!
            the problem with the fuel filter replacement (I gather) is that you need new aluminum sealing washers for the fittings on the fuel filter AND on the banjo rail. I've heard that using copper here is a bad idea because it reacts with a component in gas and can cause problems in the injectors.
            If you have a torch, you can anneal the existing washers off the car and reuse them. (heat them to around 600F, then let them cool slowly) and that will restore the workablility (remove the work hardening) of the washers.
            The Honda OEM fuel filter comes with the sealing washers according to my local Honda dealership parts guys. .Aftermarket ones won't and at least on this they are right: the two aftermarket fuel filters I have don't have sealing washers included.
            obviously have a fire extinguisher on hand when you are working on the fuel rail and fuel filter. Ideally, have another person who has a fire extinguisher at hand. At the minimum, have the fire extinguisher.
            Also, have a big bowl of water and some soap close at hand so if you get doused with fuel you can wash it off immediately and avoid being a human torch-in-waiting.
              yea I try to buy my parts at honda any chance I get or at least can afford to. LOL!!
              -Wayne-
              310whp - 296tq
                Originally posted by batever View Post
                yes yes yes!
                I changed my fuel filter out 2 years ago and the one I bought at Kragen did have the washers with them.
                Thanks.
                  yes yes yes!
                  did you really just suggest putting a cutting torch on a fuel line? that must be the worst advice i have ever heard.
                  second do not reuse washers. they are very cheap and will probably leak if you reuse old ones.
                  if you buy a fuel filter and it does not come with new washers something is wrong. ask for another because someone probably just stole those out of the box.
                  the fuel pressure relief procedure is very clear in any service manual. if you dont have one go buy it. just in case you dont have one i will list the steps for you.
                  first take off the gas cap. second on the right side of the fuel rail( standing in front of the engine) there is a bolt and an odd little nut underneath that you can barely get a open end wrench on. put a rag or 2 under that part just rest them on the IM. hold that nut with an open end wrench and use a socket to undo the nut above it. some fuel will squirt out so barely loosen it until all the fuel spills out. then remove the nut and the washer underneath. your new fuel filter should come with a new washer for that bolt.
                  then after doing this your fuel pressure will be relieved. some fuel will probably still leak out when you remove the banjo bolt from the fuel filter. you do not need to remove the banjo bolt from the fuel rail just from the fuel filter. also that threaded nut on the fuel filter can be very tough to remove sometimes. you should be very careful while doing this because bloody knuckles can occur very easily.
                  seriously NEVER put a torch on your fuel line. you will probablyh kill yourself.
                  edit: wear safety glasses and gloves while you do this. the fuel will spray when you relieve the pressure. it will get on your hands if you dont have gloves on.
                  Parts For Sale
                  BIG Thanks to HondaFan81 for all your help!!
                    Theres a little nut on the right side of the fuel rail that you open up to release the pressure.
                    I never released fuel pressure when i did mine. I just took it off and that was it.
