my 91 had a small miss in it yesterday, when i pulled out of a parking lot. i haven't driven it for about a week, but it did'nt do it when i left my house. and i drove it this morning and no stutter then. but i had noticed the maintenance required light under the factory tach was getting yellow. but when it stuttered yesterday it only did it for about five seconds, then acted as if it was running great.maybe someone has some info on why that happened. thank guys.
maitenance required
The "maintenance required" turns from green to red every 7500 miles or so, and it's yellow somewhere in between there.
It doesn't mean anything is wrong with your CB. It's just a reminder to take your CB to the dealership for fluid changes and an overall checkup.
It says something about it in your owner's manual.
If you want it green again, stick your key into the rectangular hole on the left side of your cluster.
Yes, the maintenance required indicator is nothing but a mileage counter. You stick your key in the hole next to it and it goes back to green. 7500 miles is what it counts to, and 7500 miles is what Honda's suggested oil change interval was on these cars (I wouldn't go above 5000 myself... making that thing useless)
As for your problems... is your check engine light on? THAT indicates a significant problem, and it will also tell you what it is.
Otherwise, all we can do is guess, as bcjammerx did. All of those things he mentioned, along with a handful of other things he didn't mention, could all cause those symptoms.
thanks guys . i'm going to do a plug change and i'll let you all know, and thanks again for all the advice. god bless. sorry man, no check engine lite on.thanks.Last edited by stretch JDM; 08-10-2010, 12:38 AM.
