Couple moths ago was driving to work and car shut off on me out of the blue my father and I kept looking for the problem until I pulled back the rug and noticed that most of the wires in the harnes inside the car were bare so we decided to change the whole harness I have a 92 DX so went to the Junkyard and pulled the harness from a 93 DX everything works motor turns over and runs lights works but one of my turn signals don’t turn on the {ones that Blink} and my cluster doesn’t light up nor work the way its supposed to if I hit the switch to turn right the Oil light blinks. Tach works and everything else works but the the interior lights from the cluster or the heater Unit all Fuses are good and wires are all covered any one have any ideas?
Cluster/Corner Light issues
could be the 93 part in the 92
alot of things are compatable though out the 3 or four years the car was manufactured
but you never know honda could have dicided to change a slight variation of the harness between the years
check all your grounds
or it could be you got a junk harness
my sugestion would be ge a thing that sensess a short in the wire and serch for it
its just one of those thing that suck-----------------------------------------------
''It is what it is, Do what you want''
http://www.cb7tuner.com/vbb/showthread.php?t=167905
