So I was wondering if riding on stock struts with lowering springs (no idea what the ratio is) is good or bad
Struts & Springs
Originally posted by sn000t View PostSo I was wondering if riding on stock struts with lowering springs (no idea what the ratio is) is good or bad-Wayne-
310whp - 296tq
Originally posted by boostedlude3g View PostI did it on my prelude for a long time with no problems, but I would recommend doing struts and springs at the same time. Once I swapped mine the ride was a whole new experience. You have to get in there anyway, why not save yourself the time on down the road. I like my yellow Koni's with ground control coilovers. I went up to the 400lb springs in the front and 300lb springs in the back. Its a real nice ride.
as for the OP... it's definitely doable, but remember it's just new springs on stock (possibly blown) struts. please don't drive like it's more than that!
edit: peace
DO NOT ride on stock shocks when lowering your car. If they're not already blown, they will blow soon enough. Blown shocks will actually cause your wheels to leave the ground over bumps, cornering, and hard braking. If your wheel isn't on the ground, as you can imagine, you can't control your car. Your live isn't worth risking to save a couple hundred bucks.
KYB doesn't make anything that is designed to work with a significant drop.
Match your shocks to your drop and your spring rate, or you're going to run into trouble. If this is too complicated for you, or too expensive (the CHEAPEST safe suspension setup should cost no less than $500 with new parts...) then I suggest you choose another area of your car to work on. Suspension and brakes are the two things you should NEVER halfass.
Originally posted by C91BLX7 View PostOem maybe you can, if they are new, if they are old, forget about it.
Why does everyone seem to think there's a cheap and easy way to do this? You HAVE to have proper shocks. You HAVE to have quality springs. You HAVE to get an alignment. A camber kit is highly recommended, especially if you lower your car more than 2".
That's it. Your options lie within those parameters. If you can't do that, please don't touch your suspension. For your safety, and the safety of others on the road.
