Ecu
    Ecu
    My 91 Accord EX Coupe 5 Speed F22B V TEC With a POA-AO1 ECU
    Do i Need to Chip my ECU Already Have Connected A4 To Solenoid And D6 To Oil Pressure Switch.............. Any Help Will Be Appreciated Thank u
    Engine Shakes and Lost Power
    That ECU is made for that engine (it's an absolute crap engine, a downgrade from the F22A that came in the CB7, but that's beside the point...) If everything is installed correctly, and working properly, then it should run properly. You do not need to chip your ECU (and the P0A can't really be properly chipped anyway.)
    What you need to do is check your wiring, make sure everything is right. Check your install, and make sure everything is right. Check your engine to make sure it's healthy. DarkCloud wrote a pretty detailed DIY for the F22B1 installation.
    You ARE using an OBD1 P0A, right?
      yes its an OBD1 POA I'm Gonna Double Check Everything Thank u
