new car, can't identify this tranny
    Ok guys, I just bought a 95' civic ex, its swapped with an h23a vtec (blue top) and I cannot figure out where my tranny came from! Its a 5 speed tranny with cable shift, serial number : T2C5-1002384. The 2 previous owners know nothing about cars and are generally useless, I need to replace my speedo sensor and I am stumped; can't figure out where this tranny came out of.
    P.S. The honda dealership was also totally useless when I called them, and I even physically brought my speedo sensor to them.
    Thanks in advance guys, any help would be greatly appreciated.
    From my understanding, its a jdm lsd tranny similar to the other t series trannys. With m2a4 gearing.
      The only thing I can find about it is that it may be from an Accord with a SOHC 2.0L engine... quite possibly the SOHC F20B. If so, it's not an LSD-equipped transmisison.
      It's not a US model transmission, which is why the Honda dealer was clueless. I'd contact a Honda dealer in New Zealand or Australia. They would most likely have dealt with it before.
        I just did some searching, it's from the cf4 SiR Accord with the 2l sohc engine. Not sure if that helps at all??
          Not from New Zealand unfortunatly, however It could possibly be from Aussie.
          My 5.7 LS1 Holden Ute
            That seems to correspond with my findings. SOHC F20B engine... basically, a 2.0L F22B1. It was pretty much the top of the line, "non-performance" Accord. Like the Integra GSR is to the Integra Type R.
              It's a Japanese model, I believe... MAYBE European, but I'm pretty sure Japanese as well (the info I found referenced the F20B SOHC as being an Asian market engine). I figured it probably wasn't for sale originally, but I'm sure plenty have been imported by now! Maybe not to NZ as much as Australia.
                Thanks alot for the replies guys, does anyone know where I can buy a JDM speedo sensor for this tranny? I've had no luck sourcing one thus far.
                  Do you happen to have a pic of it? I find a lot of the Hondas/Acuras use the same speed sensors so I wouldn't be surprised if the JDM ones were also the same.
                    The transmission is from a 6th gen Accord... I would try a VSS from one of those.
