Is This Problem From The IACV?
    Originally posted by brsteinbach View Post
    Ok, so unplug it when its fully warm, then go drive it and see how it acts?
    You think I should reset my ecu?
    thats not how you set base idle.
    I <3 G60.
      No I know that, but I was a little confuse on your last post.
      "all you have to do is just unplug the iacv and see what it is...it should take all of 30 seconds. "
      Well I went to the junk yard and got another iacv and didn't clean it out completely, just sprayed a little carb cleaner in it to get some of the carbon out of it, then threw it on. Well it idles a little low but that's obviously because I need to set properly, but it seems a little better.
      I'll update if I have any problems but it seems fixed, at least I hope so.
      Thanks for all of the help everyone.
      Click picture for MRT
      Sparkin CB7
        I am having the same problem with mine, but I have a cut-out problem also. I unplugged the IACv and the O2.. no more problems. Both parts are being shipped now.
        Click on the Death's Head Moth for MRT
        PSN: Sick6sect
        CB7Tuner Map
