head swap
    head swap
    h22 f22b vtec head
    witch would be better to swap
    what would be faster
    what head would be easyer to do the up keep on
    f22b vtec head would not be worth it, and actually any head swap isnt really worth it.
    search "head swap" to get more info.
    My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
    New people click here
      the f22 head flows really well man. i had a port and polish job done at local performance shop and got a 3 angle valve job done too. you will be happy if you do the same bro.
        h22 head swap results in lower compression...and thus lower power...it is also not a direct swap.
        Why do you want a head swap?
        ____
          The F22B1 head flows like shit, and has a horrible port design and valve angle. Not to mention a heavy valvetrain. It's a considerable downgrade in every way.
          The H22 head, as said above, will result in essentially a low-compression, low-redline H22A.
          Headswaps are not worth it. Don't waste your time or money. If you want to swap, swap in an entire engine (and the F22B1 remains a lousy option.)
          If you want VTEC, get an H22A or F20B.
            looking for more power
            i just did a new header ill see if its any better
            what are some cheap bolt ons
            i have short ram intake
            header (nuespeed)
              check it...delta 272 cam, tune, run open header and run a 3" intake with no air filter. you'll make lots of hp for cheap.
                ... until he blows it up.
                Add an h23 intake manifold and a camshaft. That's about all you're going to do "for cheap". Your header isn't giving you much power at all.
                A headswap will most likely make your engine much less reliable, and will not give you much power. Have the F22A head ported and polished, and you'll make a hell of a lot more power than you would with a headswap. Headswaps are some of the dumbest things people do on here.
                  i wouldnt call it dumb, we're just pioneers. i couldve went with a h22 lower bottom end instead of trying to put h22 pistons into a f22a. it's all experiments.
                    Yeah, but experiments are for people that say "let me try this and see if it works"... not people that have to go on the internet to ask "what's the best option?"
                    If you have to ask, you're not a pioneer. You're not experimenting, and you're not doing anything new. I have respect for the frank builders that did it out of their own curiosity. Most are just looking to build an H22 for $200 using someone's discarded head.
