stuck spark plug
    stuck spark plug
    Im freaking T-off, some pricks have no buss. working on cars. I have a strip/stuck #1 spark plug. What are my options here, has anyone dealt with this issue out there? Get at me folks, Gratz!
    laloquera
    93 sadan ls 5 speed.
    how big of a breaker bar have you used?
      Its good size, its not an issue. I tried to go back tight on it and will not lock up either. Im stuck in the middle not being able to tight or take it off. Im thinking the strip, or Im dreading taking off the cylinder head! What do you think?
      laloquera
        If the threads are stripped, the easiest solution would be to replace the head. You can MAYBE retap the threads (though that shouldn't be done with the head on the block, as it'll drop metal shavings into the cylinder, and will cause serious problems...), or you could use TimeSerts to fix it. I wouldn't suggest using Helicoil, as that's a bit weak for a spark plug rethread.
        I have damaged threads in my H22 head myself, so I've looked into this. I also bought another H22 head... That IS the easiest option... and with an F22A especially, the cheapest option. Even to fix it, the head has to come off... might as well just replace it. Sell the damaged one to someone that wants a project, or make a project out of it yourself.
          thats fucked, maybe use a set of pliers to try and get it to back out and put the socket on it again. if you strip the threads, you can always heli coil it.
            Im think I wanna take a crack on taping it, before taking off the head. But how do I get a spark plug that wont come out?
            laloquera
              laloquera
              you need to somehow pry up on the plug while unscrewing it. if it doesnt grab any remaining existing threads then your head is coming off.
              if it comes off, you might as well replace it with an undamaged head.
                too bad you're in sac, thats like 2 hours from me. could probably fix it for you.
                  I tried prying it up with a new socket with a hard rubber in it. It would not grab on, it just slip. Anything else I can possibly use to pry it up? There is not alot of room in that tube. Actually I'm in Davis!
                  laloquera
                    you can spin the engine and maybe the compression would provide enough pressure for you to get a socket on it
                      wed3k, Is that wishfull thinking or has that work for you in the past? Im desperate and willing to try anything at this point. Why not, but its gonna have to wait till tomorrow.
                        dont doubt what wes has to say when it comes to our motors. he diagnosed my head with a hammer and socket....
                        try it.
                        if the plug port can hold enough pressure to push the plug up, its certainly a plausible method.
                          Thats more clearly stated, Im becoming more optimistic. Do I manually turn the engine or do I crank it on? The spark plug is like half srewed on and half off, I can wiggle it in the tube.
                          laloqera
                            laloqera
                            crank it by turning the key. it builds pressure faster.
                            if you can wiggle it, it's likely not gonna hold much pressure at all. in which case you can try and grab the plug end with a skinny plier or vise grip and pull up as you unscrew.
                            if that doesnt work, you are very likely removing the head.
                              the idea came to me when my buddy's dad kept shooting plugs out of his camry. 150 psi aint nothing to be fucked with. just becareful and maybe keep a hand over the head of the ratchet so nothing goes flying.
                              make sure you disable fuel like the fuel resistor box.
